Drag Racing Tech - Need some help with Wiring
InsaneDomestics
03-13-2012, 09:57 PM
Im workin on the 98 Maro. I've went to a carb setup, done some weight reduction and stripped most of the interior to do some clean up with the wiring.
I just need some help on getting this thing wired back up with the bare essentials. I just want the basic Headlights H/L, Tail/Brakes and Signals. What relays are needed and how do I wire them up?
Im basically starting from scratch. Ive got the Chiltons book with a few diagrams but I dont really understand all the relays, fusible links etc. Any help would be appreciated.
SMKN TA 95
03-14-2012, 10:48 AM
Send me a PM.
spaulding
03-14-2012, 07:58 PM
I ran mine with a painless 8 circuit chaiss harness then made my own efi/ nitrous harness stand alone with seperate fuse panel to make changin set ups and tracking down problems easy you could use there 12 circuit kit to or talk to smknta95 he does some amazing work if you see his prvious threads
InsaneDomestics
03-15-2012, 01:21 PM
PM sent
I have seen some of SMKN's threads and his setup is similar to what im after. Im just confused on wiring the relays, fusible links etc.
InsaneDomestics
04-04-2012, 09:12 PM
I need some help with some of this wiring...
IGNITION
The 12gauge Red Wire goes to a Fusible Link which goes to the Underhood Fuse Block to a Constant Hot, IGN & Starter Relay Correct?
Then the 12gauge Yellow Wire goes to the Underhood Fuse Block to the small Starter fuse right?
The 12gauge Pink Wire also goes to the Underhood Fuse Block to the small IGN Fuse, Correct?
What about the 12gauge Tan Wire, where does it go?
And I also need to know where the small Orange Wire goes that comes from the IGN Plug.
TURN SIGNAL SWITCH
What are the Connectores on the Right Side of the Steering Column and the Bottom of the Steering Column? 1 is for the Blinkers right? What about the other 1?
I'm also wanting to get the Turn Signal Wires connected but I'm not certain where the go. 12gauge Yellow, 12gauge Lt Green, Smaller Lt Ggreen Wire and a 12gauge Tan Wire.
STARTER
There is a Purple/White Wire and a Green Wire that come to a Plug but I don't know what that plug goes into.
The Purple/White Wire come from the Small Starter Fuse and the Green Wire comes from the Starter Relay.
Also on the Starter Relay, the Purple goes to the Starter Correct? What about the Yellow/Blk Wire, is it a Ground?
InsaneDomestics
04-08-2012, 06:14 PM
Bump, any suggestions?
Outlaw666
04-09-2012, 10:29 AM
I'm in process of wiring my car as well and I'm in for some info...hopefully someone willing to actually help will chime in.
So far Ive pulled most wiring out and I'm tracing back all the things that I will be using (hdlmp, tail, brakes, horn etc)...I'm doing most of my wiring using the factory stuff and I will be using a push button starter for ign.
Good luck and if I find out anything extra I will be sure to post it up
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
