-TheBandit-
03-14-2012, 01:05 PM
I've been wanting to make some kind of flywheel holder because I know cranking down the VVT cam phaser bolt is going to take a lot of umph, not to mention R&R of the balancer bolt is always difficult. There is a great tool out there from Kent Moore / SPX Specialty Tools J-42386-A that bolts to the starter flange area and holds the flywheel with interfacing teeth. It runs about $80 new. Here's a picture:
http://www.etoolcart.com/images/products/display/J42386A.1.jpg
I've been keeping my eyes peeled for a used one for a while, but nothing has come up. So I've decided to go ahead and make one. I started with a piece of 1/4" steel scrap and traced the teeth of the flywheel against it. Then I made a bunch of cuts with a thick cutoff wheel as shown.
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap277.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap278.JPG
With a bit of trimming I had a whole bunch of teeth. As you can see mytooth spacing was anything but perfect, so I cut it down to just a few teeth and trimmed to fit. Here is what I ended up with.
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap279.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap280.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap281.JPG
Using bits and pieces of scrap, I cut a bridge between two pieces of tube and tacked it together while bolted to the engine. Then I welded it, bolted it back up and tacked another piece to hold my set of teeth. I wish the pictures turned out better - I'm proud of the monster I've created. Yeah it's UGLY, but the tooth engagement is pretty darn good and I think it will serve it's purpose well.
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap283.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap284.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap285.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap286.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap287.JPG
http://cjnn.xtremefabricator.com/images/LY6swap/ly6swap288.JPG
This took me about 4 hours to make from some scrap metal I had laying around from other projects. The Kent Moore tool is certainly worth the money, but this is another way to get the job done if you're on a budget.
Hope it helps someone!
