Small Block & Big Block Chevy Specific - Gen 6 Big Block
blackbelt
03-14-2012, 09:53 PM
Im going to post in the wanted section but figured I would post here as well. Im looking for a gen 6 block for a 496 build and was wondering if anyone here had a good lead on where to find a bare gen 6 big block.
Main question is How far can the Gen 6 big block generally be taken as far as bore and stroke. Is 496 build best plan? or is bigger possible? Also are all gen 6 4 bolts?
82cetuner
03-15-2012, 09:41 AM
I think the biggest issue is finding aftermarket parts for the 8.1 and your best bet is to find a escalade that had one as a option in a junk yard somewhere.
havent seen cranks pistons or rods for these engnies so good luck on changing the internals. they were quit commenly used as a marine engine I belive so you might can find some that way, i think the majority of the aftermarket is marine as well
blackbelt
03-15-2012, 11:47 AM
I was led to understand that the most of the components where interchangeable..except stuff like front cover-oil pan and some other minor things.
I have also been told that the Gen VI is a 7.4 block..I keep hearing all sorts of stuff Anyone have the right answer?
Looks like I need to do a little more research.
xx_ED_xx
04-02-2012, 09:31 AM
ok the second poster is confused. You ant to build a gen vI stroker right?
60 over i think is max on bore, best thing is have them sonic check the cylinder walls
bore x bore x stroke x .7854 x # of cylinders
so .060 over is
4.310
4.250 stoke crank
will get you
496
Whats also nice about the gen vI is you can convert it to run on a ls1 pcm. gm mde a 24 x crank reluctor and you use the distrubutor as the 1 x cam sensor
If you want anymore info send me an email
edward.coss@gmail.com
396375
04-07-2012, 09:58 PM
I saw Gen VI blocks on sale for just under $1700.Sorry.I can't remember where.It was an add in Hot Rod or one of those magazines.I'm not sure if I would spend a lot of effort finding one.The extra cubes are nice but a well built stroked 454 will make just as much power and parts are cheaper and easier to find.I just finished rebuilding my ZZ502 after finding a wornout thrust bearing.
gectek
04-08-2012, 06:20 AM
This is the best part really
http://www.dartheads.com/products/engine-blocks/chevy-big-blocks/gen-7-chevy-big-block.html
Dart saw the need for these engines because the industrial part of this nation needs a large displacement engine that makes a huge amount of tq with little maintenance and can be ran at a good RPM (4000-5000) for hours on end with no problem. That was the 8.1L. So now they make blocks, they are working on heads I hear, and maybe some intakes.
Big Al
04-08-2012, 01:22 PM
So if you bought a regular 454 could you adapt a LS style computer to it? If yes, would be a lot less expensive and easier to get internal parts. I have a brand new Dart block, with all the internals to build a 540, Callies Dragonslayer crank, Diamond pistons, Manley rods, bearings, Dart Pro 1 heads with CNC chambers, valves, rockers, pushrods, springs, Titanium retainers, valve covers, intake and so on and I'm just over $7,000 in it so far. Everything is brand new except for the intake, rockers and stud girdles.
And I'm kicking myself in the butt now because I found a running 600+HP LSX engine I can get for $6,000 complete, PCM and all. Dyno time only. Was built for a sand car and the guy wants to get out of it. Would be a natural for my 95. Kick-kick.
Al 95 Z28
gectek
04-08-2012, 08:23 PM
^ if you want that to happen, look to EFI Connection. They can do all that and its a REALLY trick setup.
xx_ED_xx
04-19-2012, 05:56 PM
Or use a gen VI BBC and buy the parts even cheaper from the factory
You can also use an MSD 6010 LS box to run the igniton side and a megasquirt 2 to run the injection. Which the software is free and is much easier to tune.
Some pics
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/l29.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/sensor3.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/sensor2.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/sensor1.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/sensor4.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/DSC01174.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/DSC00844.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/DSC00843.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/DSC00842.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/24xb.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/24xa.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/SealedVortecDistributorCapCast.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/SBC_Cam_Sync_Distributor_400w.jpg
http://i1239.photobucket.com/albums/ff513/S_B0MB/VORTEC%20454/ramjet454_02.jpg
Thunderkyss
11-02-2012, 01:47 PM
Some pics
I was thinking of doing something similar, but just use the computer out of a suburban or something. I already have the software (HPTuners), what would be the advantage of using the MSD & Megasquirt?
93Z2871805
11-07-2012, 05:44 PM
xx ED xx,
Is that an L21 or an L29? What are the details on that project? Feel free to PM me.
bww3588
11-09-2012, 04:10 AM
The problem with the 8.1 is lack of interchangeably. Heads are different so your limited to stock or stupidly priced aftermarket heads, if you can find them.
Personally, I'd build a 7.4 out of an 80's/90's vehicle. Older more available heads will work along with most other older big block parts. The Volvo pinta engines are nothing but a pain in the ass.
