Frost Cooling Fans Temperature
Old 03-14-2012, 11:16 PM
JeremyKrauss's Avatar
Default Frost Cooling Fans Temperature
Alright, I tried using the search function. Used every combination I could think of, and after half an hour, I still can't figure it out. At what coolant temperature does Frost set the cooling fans to turn on?
Old 03-15-2012, 07:40 AM
Brando5641's Avatar
you can pick the temp
Old 03-15-2012, 10:31 AM
So if I don't select the temperature, does he leave it at stock?
Old 03-15-2012, 10:40 AM
oange ss's Avatar
why dont you ask him ?
Old 03-15-2012, 10:53 AM
When I posted this up last night, I figured he probably wasn't at his shop...just trying to figure things out before I started for the day. Just contacted him, I'll update this in a minute when I get a reply.
Edit: "I assume you have a stock thermostat and lower them accordingly. You have to ASK to have them left stock for me not to lower them."
Will update when I know what temperature he sets them to come on at.
Update: "Its complicated... Where the pcm runs them is not the same as actual measured ECT. Low is in the low 190s though and high is under 210. Keep in mine this is not actual ECT"
