ls1 fuel injectors?
Old 03-15-2012, 12:01 AM
davidc212k's Avatar
Default ls1 fuel injectors?
planning on getting these for my LS1 swap.
Will they work with the stock LS1 harness or will i need to do a mod.
also running stock LS1 Intake.
Will these do?
http://www.ws6project.com/user_stor/...-hr-injectors/
Old 03-15-2012, 04:37 AM
LS1MCSS's Avatar
Better off to just find a set of stock injectors.
Old 03-15-2012, 05:05 AM
mark21742's Avatar
If you don't have any injectors at all, just do yourself a favor and start off with 36lb injectors...if you have a stock set just use them. Most stock were either 26 or 28 depending on year
Old 03-15-2012, 09:57 AM
davidc212k's Avatar
will they fit in the stock ls1 harness fuel injector plugs?
Old 03-15-2012, 10:27 AM
mark21742's Avatar
You can get direct drop in....when your looking, we run high impedance injectors...if you grt low impedance injectors you will need adapters and resistors
Old 03-15-2012, 10:30 AM
Internet Mechanic
BlackScreaminMachine's Avatar
The plug is the same, Red tops, green top whatever you want. Just need to tune for them accordingly. Also, look for a LS6 intake, check the part #, better flowing, will make great power up to heads/cam.
I always liked Racetronix for fuel pumps and injectors. Sponsor ---->
If you ever plan on Nitrous go 42's all day.
Old 03-15-2012, 10:41 AM
mark21742's Avatar
Or if you open on going bigger you could run 60lb injectors like me
Quick Reply: ls1 fuel injectors?
