Fueling & Injection - ls1 fuel rail weld on bung?
birdman2447
03-15-2012, 12:17 AM
I am tired of worrying about the reliability of my russell -6 AN to the ls1 fuel rail fitting that is known to fail. I would like to weld/braze a bung to the rail. Is it possible to do this to the factory rail? I know its thin material but i think i could tig it. Just wanted to check to see if this is a common mod.
BigRich954RR
03-15-2012, 06:04 AM
This is not done ever cause rail are cheap up grades, but it can be done by a very good tig welder. key word is very good as not to get a brittle weld that breaks with 60 psi of gas flowing though it while the engine is shaking all over the place
gi8e7oi825
03-15-2012, 06:14 AM
Well it's certainly not "not done ever". In fact, I somewhat followed Racetronix's idea here, http://ls1tech.com/forums/10171951-post19.html, but using only -6AN
Ollie8974
03-15-2012, 08:07 AM
Russell offers an improved version of the quick connect fitting.
Photo #1 old style push on.
Photos 2,3,4 new style with threaded locking ring.
birdman2447
03-15-2012, 09:33 AM
BigRich954RR, that is exactly what i am worried about, I am very competent with tiging stuff that dosent matter, exhaust etc... I like the silver solder idea but dont know how much i trust that also.
reddfox
03-21-2012, 06:13 AM
I am also wanting to braze on a fitting to the fuel rail I saw this aeroquip fitting (FBM2872) and I think it will work
gi8e7oi825
03-21-2012, 11:01 PM
Well, it's definitely do-able. I bought two of Aeroquip's FBM2872 last July from Summit (don't pay more than $2.48 each!) and had them attached to my fuel rail by some highly recommended guy who tig welds for a living (or something), but a little differently than being discussed in this thread (on the rear of each rail). Before installing it, I'm going to pressure test it. That should be within the next few years lol
http://img696.imageshack.us/img696/1618/p1000162e.jpg
bczee
04-02-2012, 11:24 PM
I have brazed a AN Bung on my fuel rail. Have had no issue and easy to do.. It is more secure than using the QD's.
http://i190.photobucket.com/albums/z296/BajaCruz-in/71%20LS1%20Chevelle/DCP_3757.jpg
Tip: don't brother with the high cost name brand fitting. If you have a Tubing/Hyd shop.. they sell the fitting and bung in bulk. I picked up 3 3/8" pipe to AN -6 adapter for less than $5.00, These are cheaper than a regular Weld on Bung. Cut the Pipe end off, drill the adapter about 1/4" deep for the Tubing to fit in and then just braze/Tig/weld it on..
BC
RaceDriver
05-07-2012, 04:17 PM
Do you have the part number for the new style?
Do you have the part number for the new style?644120 for blue & 644123 for black.
RaceDriver
05-07-2012, 04:54 PM
Awesome, thanks. Going to replace mine, I have the old style.
