G body turbo manifolds
Old 03-15-2012, 06:55 AM
IT_SS's Avatar
Default G body turbo manifolds
What are the g body folks using for turbo manifolds? Will reversed truck manifolds work?
Old 03-15-2012, 08:32 AM
Old Geezer's Avatar
Try a search... Several threads on the topic....
Some over @ www.turbobuick.com, too.
Old 03-15-2012, 09:58 AM
driven87's Avatar
little pricey but i went with virginia speed headers...
Old 03-15-2012, 11:22 AM
Rat Raceway's Avatar
Can you put your inner fenders back in with them or no???
Getting ready to start a a 87 MCSS turbo build.
Old 03-15-2012, 11:26 AM
IT_SS's Avatar
those VA Speed pieces are nice, theres a member on here with w GN who has truck manifolds flipped up but since I'm not running AC or PS I was curious about the clearance with the manifolds flipped down
Old 03-15-2012, 11:29 AM
driven87's Avatar
im sure if you put the turbo in a different spot then where i have mine you can put the inner fenders back in for sure
Old 03-15-2012, 01:01 PM
deeloc1's Avatar
This guy used a ls4 manifold on his nova setup. Fyi, that's the ls4 manifold on the driver's side in the up and forward configuration. Our biggest problem with our g-bodies is finding a header or manifold that will clear the steering shaft. The ls4 manifold looks like it will!
This guy uses the same ls4 manifold on the passenger side for down and foward and a passenger side truck manifold on the driver side for down and forward configuration. For up and forward he puts the ls4 manifold on the driver side and the truck manifold on the passenger. He has a Nova also...
Originally Posted by 2baditsnotachev
Test fitting the 5.3 outside 12° I used neutral position transdapt plates with moroso solid mounts and just dropped in with the truck pan although the sump hangs way below the crossmember. I want to use an ls4 manifold on the passenger side and the truck manifold on the drivers to get a down and forward setup. I plan to try a manual steering box next to see if I can get the truck manifold in.
If I can't get them to work down and forward ill just run them up and forward
I've been wondering if the stainless works up and forwards would fit without hitting the steering shaft? If so, an even cheaper route would be the obx up and forwards that are $400 and stainless! They seem to have the same design as the SW. Here's a passenger side comparison that a member on here rigged up.
https://ls1tech.com/forums/attachmen...camaro-lsxt1.jpg
I've thought about taking a chance on the obx's and hoping they'll fit with a aftermarket g-body steering shaft like the TRZ with 3 different swivels for mounting relocation if the stock steering shaft hits the header. I'll probably end up going custom headers though.
Here's some pics of the headers on Yellowbullet (not on a g-body but you get a good look at the obx's):
Here's obx's on a fox with a view from the top. I'm thinking that on a g-body, the steering shaft will fit right under the last primary on the driver side.
https://ls1tech.com/forums/attachmen...-mustang-5.jpg https://ls1tech.com/forums/attachmen...-mustang-6.jpg
Here's a pic of the SW on a nova and a 3rd gen camaro (not a g-body but you're able to see how the primaries are set up and compared to the obx fitment. These pics of the SW headers are what made me think the OBX's may fit.
[/QUOTE]
This pic in particular of the SW header is what made me think the OBX headers could possibly fit a g-body
Here's another pic from YB with custom down and forwards. You can also try to guesstimate where the obx's would fit if mounted to that same engine. Compare this pic of the steering shaft on the pic below, to the header onthe pic above...I think the obx's will be very close or need just a little massaging. It think they'll fit without a problem with a aftermarket steering shaft or a jeep cherokee shaft. That bulge on the stock shaft is what limits us too.
[/QUOTE]
Then there's the VA speed headers For $1400+ after shipping/tax.
http://shop.virginiaspeed.com/product.sc?productId=155
I have not tried any off this...just giving you food for thought...lol!
Old 03-15-2012, 06:59 PM
IT_SS's Avatar
thank, tha OBX looks interesting
Old 03-15-2012, 08:28 PM
tta656's Avatar
I also would love to hear if these UP and forward OBX would work in a G body
also where would ps and alternator placement be if using these
,,i am sure i am capable of massaging the one primary if it doe hit the steering linkage..
Old 03-15-2012, 09:29 PM
deeloc1's Avatar
They'll work with the power steering and alternator if you have f-body accessories.
Size:  160.7 KB[/QUOTE]
Old 03-16-2012, 12:46 PM
IT_SS's Avatar
are those OBX or Stainless Works?
Old 03-16-2012, 02:19 PM
lazaris's Avatar
What intake and elbow are you using? What car is that? Stock hood?
Old 03-16-2012, 04:20 PM
deeloc1's Avatar
Those are SW...but the OBX's look identical to the SW so i think it's safe to assume that the OBX's will clear the PS pump and ALT.
Old 03-16-2012, 04:21 PM
deeloc1's Avatar
Intake looks like a Vic Jr. and the elbow looks like Aarons elbow.
Old 03-16-2012, 05:09 PM
IT_SS's Avatar
the truck manifold setup looks like a winner;
Original thread; https://ls1tech.com/forums/conversio...win-turbo.html
Old 03-16-2012, 07:28 PM
deeloc1's Avatar
NICE! Looks like i won't need custom headers after all...lol! I'm gonna weld 2-1/2" v-bands on those truck manifolds tho. I have 2-1/2" billet valve covers though...looks like my valve covers may hit those truck manifolds. I think the stock flanges with gaskets on the truck manifolds may leak with my set-up If i run 20psi??? Anyone run atleast 20psi with stock flanges?
Old 03-16-2012, 08:59 PM
driven87's Avatar
intake is a victor junior with an straight 90 elbow from intakeelbows.com. car is a grand national. has a 2.5" cowl hood on it im sure it would not have cleared the stock one the way it sits right now.
Old 03-16-2012, 09:58 PM
BLWN1's Avatar
Pm me a link to the obx headers... I'll google when I get home..
Old 03-16-2012, 10:47 PM
LS1NOVA's Avatar
FYI, the up and forward LS4 hits the steering shaft on a G body.
Old 03-17-2012, 01:24 PM
IT_SS's Avatar
98Z28CobraKiller
Quick Reply: G body turbo manifolds
