Oil pressure new pump not good
Its a slp oil pump not to say thats the problem anyways oil pressure when I start the car takes about 10 seconds to come off zero, but then it comes up to 40 and stays there then when I drive the car it runs below 40. But then when I start to run the rpms up 3k or more it drops pressure and the higher the rpms the more it drops.. Any thoughts.
My LS1 did that, ended up being the o-ring. I had installed the SLP double roller chain and it comes with a spacer for the oil pump. I made the mistake of bolting up the pump and then the pickup tube. (this is in a Corvette so the F-bod may be different). The o-ring was seated diagonally and leaked. I had to tear it all down, replace the 0-ring, and made sure I installed the pickup end with the 0-ring first.
