New member a/c relocate question
I'm a new member that is beginning a 5.3 (2005 silverado)/ 4l60e swap into an 88 monte. I've done a lot of reading in the forum's and boy what a big help!!! Thanks to all that have put up information. I will add to it as I progress:
Question: I want to relocate the a/c compressor (bottom to top mount) and want to buy a kit. I want to use the Denso compressor that came with the motor. I see a lot of info for the sanden compressor but not the Denso. Does a kit exist? Does e-one suggest I not use the Denso and buy a sanden? If a kit exists, where can I get it?
Thanks, Jim
Thanks, Jim
Contact kwik performance, I just bought a kit it's 199, u should definately switch to a sanden 508 compressor, anything compresser "508 style" will work sanden brand is more expensive. The sell a copycat on in eBay
There was a kit for f body spacing, but not for truck accessory spacing.
Check with Twin Turbo, he might have found something.
https://ls1tech.com/forums/conversio...sor-mount.html
I think dirty dingo might have a bracket now, and if so I'd do that over the kwik in a heartbeat. Would this work? http://dirtydingo.com/store/product_...oducts_id=1378
I thought I read that it is not compatible, I will get the sanden set-up, thanks again!!
