Did I goof on this setup??
I need the car to breathe better so I went ahead and ordered the Hooker LT coated, Y -pipe, Hooker exhaust, O2 simms, along with the FTRA....while at it ..I also ordered NGK's TR-55 and Taylor Thundervolts....in other words mods not in my sig...My car is an a4 with added 3.73/ TA cover/ with moser axles....should I have gotten a TC???...instaed of headers??? or did I do alright...I would have needed Drag Radials, and suspension mods ,a tranny cooler..had i opted for a TC (Vigilante)....But how did I do in going with breathing better than taking off better???..My 3.73's take off hard already but I could only have gone one route.......Which would have shaved off time of my et???
you done just fine...
do the tc next go round...
as long as you end up with a tc later then your ok....
your track times might be a little better if you did the tc instead ... but with the stuff you did the differance would not be much...
tc is good for 4-5tenths in the 1/4
ftra is good for 1 tenth
headers with y pipe good for 3-4
so either way your gonna be close to the other... and the headers and ypipe sound yummy... and though the cutout even better
www.ls1sounds.com
check there
www.ls1sounds.com
check there
Well I might do LT's and orp first also..... even after reading pages and pages on what a stall can do for an A4, I still want to gain hp first and hopfully get a trap speed over 110 and then do the stall then go low 12's all day. This is just personal preference, i'm not wraped up in just E.T's ,most of my fun is on the streets anyways
