Ronny_02_WS6
03-16-2012, 09:56 AM
I just put my car back together with LT's and ORY once started it, it was leaking coolant by the driver's side header collector, any idea what might be, its only when the car is running, when I shut it off the leaking goes away???
Ronny_02_WS6
03-17-2012, 02:34 AM
I put new head Gaskets and now I see Milky oil, Please help!!!
jimbos'ss
03-17-2012, 03:01 AM
thats most likely a blown headgasket. gonna have to pull the heads. when you put in the new head gaskets did you remove all the old gasket material? also did you check the heads to see if they were warped?
Ronny_02_WS6
03-17-2012, 11:10 AM
I just found out it's the driver's side head gasket theyre new buy I should've clean them more thoroughly, gonna have to pull the drivers side head and replace the gasket and bolts :( that's gonna suck!!!
