Carbureted LSX forum - Losing fuel pressure after hot
View Full Version : Losing fuel pressure after hot
GiggleJuiced_SS
03-16-2012, 10:39 AM
i have a question about electric fuel pumps/regulators. this is on a first gen block, so im not sure if im posting in the right section. i have a issue with my pump losing pressure after its warm. i have it set ~8 psi but when it gets hot like operating temp, it will drop below 3 psi, then shoot back up to normal again. i noticed this last night after it shut off after a hard pull on the way home. must have ran the bowls dry. its a demon carb btw. now i havent hooked up the return line, is this needed? and if so does anyone have instructions on where/how to do this? i have searched with no success. thanks.
ZONES89RS
03-16-2012, 01:16 PM
Mechanical? Never used one but for scrap metal.
xpndbl3
03-16-2012, 02:46 PM
what are you using for a gauge? one of those 1.5" cheapies? they don't read right after getting hot
ZONES89RS
03-16-2012, 02:58 PM
If it seems to be running out of fuel, it is probably not the gauge.
GiggleJuiced_SS
03-17-2012, 12:27 AM
its an electric fuel pump. we bumped the pressure up some and it seemed to help, but its still running outta fuel on the top end. any recommendations for an inline fuel pump like a certain brand?
underacheiver
03-17-2012, 12:33 AM
holley blue is a ole reliable. holley hp125 is what im about to try.
ZONES89RS
03-17-2012, 02:44 AM
Yea, holley blue and the like are fine, any of the name brand pumps for 125-150 out there are generally great.
GiggleJuiced_SS
03-18-2012, 12:31 AM
good deal. thanks for the help guys.
Monte1984
03-19-2012, 12:57 AM
Check yur float level.... Nothing to do with the pressure but might be why it's running out on top end...
