murdock.dean
03-16-2012, 07:20 PM
Looking to sell or trade my 92 mustang with a 466 big block in it. The motor is a 460 bored 30 over to make it a 466. The motor has forge internals, cam, offenhauser intake manifold, Holly 750 double pumper carb. Motor is backed by a build C6 transmission with a reverse manual shift pattern. The rear end has 373 gears in it, lower control arms, torque box welded and sub frame connectors. Has a 10 gallon fuel cell in the truck along with the battery relocated there and the power shut off switch. Car does have an electric fuel pump in it. Most of the trunk interior is missing due to having the battery and fuel cell there but only a couple small pieces missing from the rest of the car. The motor does have a nitrous plate on it but has never been ran since the kit is missing a bottle. I do have a line locked hook up and works great. The motor does still have stock manifolds but i do have long tubes to go with it just havent had time to put the motor plate in so i can run the long tubes. Does have true daul exhaust running into flow master 40's dumping before the rear axle. The link below is a video of it idling in the barn the other day. The paint and interior are not prefect but should run low 12's high 11's on motor and deep into the 10's or faster on nitrous. Im looking to get into more of a street car and would like a 98 or new trans am, camaro, or 99 and up mustang and mostly standard but dont be afraid to make offers, thanks. You can PM me on here or text me at 315-323-8045, thanks again.
http://www.youtube.com/watch?v=ERCIBMNKicc&context=C457c2d1ADvjVQa1PpcFPFBmgDcrbSXUL7eYUHhmo2 07OAdJ7FeD0=
