**What Engine Oil Cooler are you using?**
I dont know how big of an oil cooler to run, Im almost done installing my new set up (see Sig) and I know I want to run an oil cooler because we know Ls3's run a lil hot. But Im not sure how big of oil cooler I should use? I ordered the improved racing slim oil cooler adapter and will be getting the thermostat as well, It will see mostly street time and Its only out in the summer here in Chicago. I would appreciate it if you would chime in and tell me about your set up and if possible post up some pics of your set up as well.
Thanks
Thanks
You need a thermostat on this deal you know that right? EDIT never mind lol, reading rules me.
If you put the cooler where it can get a good bit of air you can use the smaller one, if not the larger.
If you are not road racing, running on the topside for extended periods of time or track daying this car I see no need for a cooler. Just my 2 cents.
I trackday my LS1 and dont have a cooler, I do change the oil every 2 events though and am looking into a cooler now as my driving is getting a little better.
EDIT 2, mount it like the instructions say. Fittings mounted on the side, hot oil in the top fitting. Dont mount the cooler with both fittings facing down or up, always to the side on this style cooler(Or so I read it somewhere)
Sorry I didnt mention that but hell yea I will be heading out to the track now that I got my 9" lol I say once or twice a month. But with my mods and this heat here I think I will be needing it. Its all out and I have access to everything so while im in might as well add some insurance you know?
IMO, you are just adding un needed weight and the possibility of leaks to a car that doesn't need it.
Just run a good synthetic oil(Redline, Royal Purple etc.) you will be fine.
Drag racing and road course(Trackday's) are totally different. Trackday's are 30 minutes at a time wide open, drag racing 10-15 seconds at a time.
If anyone else has pics of their setup I'd appreciate that too!
Fastfatboy thanks for the chimes if you think of other stuff please chime in. Let me know what you think of those parts.
you can use the c6z06, or the zr1. the z06 cooler will bolt right on the car using the z06 lines. the zr1 cooler is way more pricey and takes up more room. It bolts to the block just like the z06 but you have to remove a freeze plug. then run a hose from it to one fitting on the cooler and the other hose taps in the driver side rad hose. I would use one of these coolers do to the fact its OEM.
Kleeborp the Moderator™
I'd be very curious to see if you can get that oil cooler adapter to work with f-body headers, especially ones with 2" primaries. I had 1-7/8" Kooks headers on my Camaro, and there just wasn't any room above the filter to run an adapter like that due to how the primaries are run. An oil cooler was something I had always wanted to do before I sold it, but I never got to it due to the amount of work (and money) it would have required to do it right.
Used Dorman replacement lines for oil cooler adapter
First approach on install
Cut to size, flared with tube sleeve and tube nut
Used an AN8 T fitting for a custom oil temp sender install
Did not have another AN8 tube nut availiable, so I modified a Brass flare nut to accomodate the aluminum sender adapter
Header clearence after a little massage. this is with KOOKS HEADERS 1 7/8 primaries
Do you really need -10an or is -8an sufficient? At which point do you need to move up to -10an? Just curious as I have not run a cooler. I have one sitting on the shelf and was thinking about installing it with some extra -8an line i have sitting around. RGSS what is the part number or application for the cooler lines?
I am just wondering if -8an is ok spinning 7000 RPM. If I have to spend $100 for -10an to plum it. I may just leave well enough alone. There is a bypass anyway isn't there. Sorry to highjack the thread, but its a good discussion on oil coolers.
