Differences is LS1 and LS6 intake(visual)
Old 03-17-2012, 04:09 PM
01BlueSS1995's Avatar
Default Differences is LS1 and LS6 intake(visual)
Is there a visual difference between an ls6 intake and an ls1 intake, im trying to figure out all the mods on the Ws6 we have.
Thanks!
Old 03-17-2012, 04:29 PM
conan's Avatar
Ls1 intake has a hole right behind the throttle body for the egr, the ls6 does not have a egr. Ls6 intake has a flat bottom the ls1 has a bump in the middle.
Old 03-17-2012, 04:44 PM
blue98Z's Avatar
What he said^^^ except if it came from a 97-00 vette. They didnt have egr's so their ls1 intake wont have that provision. Easiest way to tell is the flat bottom.
Old 03-17-2012, 04:50 PM
FIVEPOINT7's Avatar
I thought the LS6 intakes had some sort of raised grid on the bottom?
Old 03-17-2012, 06:06 PM
conan's Avatar
Here's a pic from how to, ls1 on left, ls6 on right.
http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg
Old 03-18-2012, 01:06 AM
SOMbitch's Avatar
Flat bottom good.....V-bottom bad...
Old 04-16-2012, 12:13 PM
perf0rmance's Avatar
How about from the topside?
How else could you tell?
Old 04-16-2012, 12:23 PM
J-Bru-Ha Z-28's Avatar
I don't rember where the PN is on the intake but if you can find that, obviously that would be best. Since you have a WS6 odds are low that you have a 97-00 vette LS1 intake so if the EGR hole is missing that is probably going to be you best indicator without the PN. However there is an exception to that as well, SLP did mod LS6 intakes with provisions for the EGR system. I know first hand since I just put the SLP intake on my car this weekend, I don't run EGR so I have put a cap on the fitting.
Old 04-17-2012, 09:16 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
I've noticed that the part number on the LS1 intakes I have had hands on are on the right(passenger) side of the intake and the LS6 intakes I've saw are on the left(driver) side
Old 04-17-2012, 01:20 PM
towards the radiator or the transmission? The engine is still installed in the car.
Old 04-19-2012, 10:48 PM
Z28/2002's Avatar
The part number will be on the middle of the intake, towards the edge
Quick Reply: Differences is LS1 and LS6 intake(visual)
