Help slp pulley stuck
this^^^ if your using a crank pulley bolt to pull it on then you may not be applying enough torque however you could also strip it out. either get the correct pulley install tool or go take the pulley off and heat it for 30 mins in the oven at 225 degrees. take it out with oven mits and it should literally slide right onto the crank with no problems.
I had the same problem with the SLP the tool shown is correct. Put the three bolts in the pulley and use a socket to after the crank bolt is off and put the socket in its place to used as a extension and it will work perfectly. I've pulled mine off a few time with no problems.
