Carbureted LSX forum - Fox body guys...how did you run fuel system?
streetknight2
03-18-2012, 01:32 PM
Just wondering on how you did your carb'd fuel system on your mustang. I thought I was good to go as my roller had a sump in the tank, -10an line out to a duel inlet/outlet fuel filter, -10an line into 2 separate Holley Blue Pumps, -8an line out of the pumps up to the front of the car.
Well, the pumps are old, I rebuilt one and bought 1 new one to try to utilize what I had, but can't get fuel to the front, just trickles out. After actually analyzing it for a little bit, my pumps and filter are mounted on the bumper cover bracing, which is higher than the sump on the tank. These pumps are gravity fed, so I'm assuming that's my problem, but see no real way to remedy the situation using what I have.
SO, how did you guys do yours? Fuel cell, sump?
Thanks for any help.
