General LSX Automobile Discussion - 2002 Lq4 into a 2000 camaro
Kooljames20
03-18-2012, 06:36 PM
I have a 2002 camaro I'm putting a lq4 into is there anything specific i need to pay attention to? Do i just through my flywheel on and go?
Kooljames20
03-25-2012, 03:57 PM
bump!!!
indianass
03-25-2012, 06:12 PM
im in the middle of the same thing i think its just flywheel, sensors, and your accessories.
JaYZeig
03-26-2012, 06:17 PM
theres a massive thread about this floating around...BUT when i did my lq4 swap into my 99 t/a...i had to swap....
-oilpan
-sump pickup
-windage tray
-i would swap the flywheel to keep it with the same converter
-drill a hole for the alternator bracket
-swap crank pulleys (theyre different)
thats all i can think of right now what i did when i swapped
2000TransAmWS6
03-26-2012, 06:59 PM
The swap for me wasn't too hard, but you do have to relocate a couple of ground wires. I would highly recommend tapping a hole for the alt bracket. Napa was the only place that I found that had the correct tap in stock
Kooljames20
03-26-2012, 09:00 PM
okay thanks everyone ill have to finish building the motor and then put it in but i just wanted to have a idea what i was up against lol if anyone else has anything else chime in!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
