exhaust manifold collector bolt thread size??
Old 03-19-2012, 01:39 AM
SIKHS 5's Avatar
Default exhaust manifold collector bolt thread size??
im running stock manifolds(lq4 on the pass. - ls1 on the drivers), i cant seem to find the nuts i need for the collector bolts. my dad owns a hardware store and i literally tried everything. i know its not 7/16-14 or m10...
does anyone know the thread size/pitch of the bolts or the nuts or anything
thanks
Old 03-19-2012, 05:13 PM
SIKHS 5's Avatar
Bump.
Old 03-19-2012, 06:12 PM
bczee's Avatar
It's a metric stud and nut.. I think it is 10m x 1.5m (if not it will be the smaller 8m x 1.5m).
Using SAE on Metric (and the other way) is like putting a round nut on a square peg.. I might be close.. but your not going to like the results. !
BC
Old 03-19-2012, 06:31 PM
SIKHS 5's Avatar
BC
I tried using m10 1.5 the other day and had no luck :/ multiple nuts on all the studs and they would all get stuck about a 1/4 of the way down. The Studs seem slightly tapered, not 100% sure though.
Old 03-19-2012, 07:40 PM
71403's Avatar
Run a tap thru the holes first especially if you had to use a torch to get the old ones out. Can't speak for the truck manifolds but LS1 cast iron pieces here were M10-1.5
Quick Reply: exhaust manifold collector bolt thread size??
