kevinbushman
03-19-2012, 06:42 PM
The connector for my headlight keeps falling off of my headlight. The light works perfectly but I keep having to remove the bezel to reconnect it.
It's so bad that it doesn't even last longer than a few miles. I used to have to fix it once every 2 months.
I'm thinking of the following options:
If I replace the headlight maybe the connection will stick?
Should I replace the connector itself?
Should I use some kind of adhesive or just a rubberband to strap it down?
What do you think? Anyone else have this problem?
This problem has been slowly getting worse.
