Small Block & Big Block Chevy Specific - 3rd gen camaro swap questions
View Full Version : 3rd gen camaro swap questions
1C3 MAN
03-19-2012, 09:30 PM
Okay guys here's the deal i'm in the middle of swapping a gen 1 383 stroker into my friends 1992 camaro which had a 350 TPI motor. we got the old motor out and the new one in but the accessory bracket bolt holes don't line up at all. I was under the impression that being that his motor was a gen 1 sbc they would work just fine.
Any ideas?
Paul Huryk
03-20-2012, 11:18 AM
Some SBC heads have different locations for the accessory mounting holes (some have no holes).
1C3 MAN
03-20-2012, 12:18 PM
Yea thats what i figured but now the problem is WHAT BRACKETS WILL WORK!
I know these heads are standard chevy pattern but i'm confused because when i asked over at thirgen.or(g) they told me that the 350's that came in those camaro's were also standard chevy bolt pattern.
f body lover
03-22-2012, 03:00 PM
Which bracket the camaro has?
ATCFLYBOY02
04-02-2012, 08:02 AM
If you have some time, go to a junk yard and see if they have a truck w/a 400 in it... Pull the brackets off of there (its NOT going to be a serp system btw) OR if you have the $$, call Summit and order a new bracket kit... You'll have to know which heads you have so they can order the right stuff!
xx_ED_xx
04-02-2012, 10:17 AM
they should line up pics would help tremendously
1C3 MAN
04-03-2012, 11:31 AM
Hey guys i made the old brackets fit. i had to oval out the holes on the brackets to do it but atleast they will work for now.
they were about 3/4 of an inch from lining up.
