Any video on installing Camaro headlights?
Old 03-19-2012, 11:55 PM
robertbartsch's Avatar
Default Any video on installing Camaro headlights?
Thes are installed with only two bolts....right?
Old 03-20-2012, 12:11 AM
Cosmos's Avatar
Is this a serious post?
Old 03-20-2012, 12:26 AM
PACKERSz28Camaro's Avatar
Remove one bolt. Then slide old assembly out. Slide new assembly in, reinstall bolt.
Old 03-20-2012, 01:23 AM
6898camaross's Avatar
WOW..... Probly the easiest headlight in the world to remove
Old 03-20-2012, 01:27 AM
Definitely ranks up there. Lol
Old 03-20-2012, 03:13 AM
RoidedSS's Avatar
ya there are 2 "tabs" on the back of the headlight housing that slide onto brackets. thats the only catch to them, otherwise remove the bolt that connects to the bracket and the headlight itself..
Old 03-20-2012, 08:35 AM
CamaroSS27's Avatar
Ya its just one bolt and slides out.
Old 03-20-2012, 09:00 AM
Formally Simplɘ Jack
BoricuaHec01's Avatar
Wait a tick, didn't you post something like this back in January with a perfect how-to video in it?
https://ls1tech.com/forums/general-m...99-camaro.html
Old 03-20-2012, 02:47 PM
MEGATRONSS's Avatar
It's probably easier to unbolt the headlight and the bracket, but yes it's easy.....and give the guy a break CAR SNOBS!!
Old 03-20-2012, 03:49 PM
Drokkers's Avatar
for real! you dont know, what you dont know, and the only way to know is to ask a question about it!!! jerk faces
Old 03-20-2012, 04:51 PM
Which bolts are used to remove the headlights and which bolts are used to adjust the headlight position?
thx...
Old 03-20-2012, 05:17 PM
Captain Double Post
BOBS99SS's Avatar
Yeah but a simple search usally brings up all the info you could ever do
Old 03-20-2012, 05:34 PM
Ls1CamaroGuy87's Avatar
thx...
Take a close look and you'll figure it out. The adjustment ones are gold, sit vertically, and are star-shaped, and the bolt to remove the headlight is a standard hexagonal bolt that sits horizontally.
Old 03-22-2012, 09:54 AM
Cosmos's Avatar
Nobody search anything anymore, you know that.
Quick Reply: Any video on installing Camaro headlights?
