Pontiac GTO 2004-2006 - CTS-V brake swap thread
View Full Version : CTS-V brake swap thread
99twinturbofirebird
03-20-2012, 08:16 AM
build thread-
http://www.novastreetscene.com/showthread.php?2671-04-07-CTS-V-Brake-Swap-on-a-04-06-GTO&p=30914#post30914
mark21742
03-20-2012, 10:27 AM
I ran 14" 2011 Camaro da drilled/slotted rotors on my 04 GTO with the CTSV 4 piston calipers and loved them
chance575
03-21-2012, 04:52 AM
Finished mine last week, good upgrade
99twinturbofirebird
03-21-2012, 11:00 AM
is it worth going to the 14 inch camaro rotor compared to the 745i rotor. How long was the install?
TriShield
03-21-2012, 01:26 PM
I'd probably be more interested in this if they could be made to mimic the look of the stock calipers (red, GTO on them).
Robofuzz
03-21-2012, 09:41 PM
You can paint or powdercoat them red.
chance575
03-22-2012, 01:46 AM
install was easy, longest part was grinding on the calipers to get the brackets to fit......maybe 4 hours at the most due to sanding and painting calipers
99twinturbofirebird
03-22-2012, 02:28 PM
will the 14 inch rotors fit on a stock 18 , i know you got 19s
btw : chance i love the look of your car
99twinturbofirebird
03-22-2012, 02:30 PM
i plan to paint them red with black GTO lettering or black with red lettering ......... i have stock 18 that are painted black:
http://i3.photobucket.com/albums/y92/nightshifterz/2012-03-06_063903.jpg
Dayton937
04-02-2012, 04:32 PM
Pulse Red is pretty much an exact match color wise for the stock caliper color.
Grafxwerks will print custom sized "GTO" caliper decals. I had mine made to 4" x 0.58" which maintains the original aspect ratio.
Pulse red, decal, clear = stock look
Someone else also grabbed the "GTO" lettering stencil and painted in white then cleared over it.
99SilverC5A4
04-04-2012, 09:39 PM
i did this:
http://i247.photobucket.com/albums/gg147/06quicksilver/IMAG0183.jpg
http://i247.photobucket.com/albums/gg147/06quicksilver/IMAG0203.jpg
http://i247.photobucket.com/albums/gg147/06quicksilver/IMAG0223.jpg
i had to do the rear.
99twinturbofirebird
04-09-2012, 09:33 AM
looks good
audacious nick
04-09-2012, 02:49 PM
Are those the actual HSV rears, or what caliper is that?
99twinturbofirebird
04-11-2012, 07:31 AM
those are the 09 + cts-v 6 piston front right?
ryeguy2006a
04-18-2012, 12:22 PM
nice upgrade.
409CISecondGen
04-20-2012, 06:21 PM
i did this:
Those won't fit behind the factory 18's will they? :(
RsSean
04-20-2012, 07:15 PM
Wheres a link to the 6 piston write up or a brake write up in general with part numbers
409CISecondGen
04-21-2012, 12:03 PM
http://www.ls1gto.com/forums/showthread.php?t=431832
I would think getting the bolt on Wilwood setup would be cheaper/easier. Its like $1600 IIRC
99twinturbofirebird
04-21-2012, 02:49 PM
i dont believe so , i think you need 19s
99SilverC5A4
04-21-2012, 05:29 PM
they will not fit behind factory 18, but my wheels are 18s. the factory 18 steps down right at the spoke this is where it hits the caliper, aftermarket wheels do not step down.
mark21742
04-22-2012, 01:37 AM
I had plenty of room on my aftermarket front 18s, but I put my stock front calipers on the back with the 14" rotors and had to do a LOT of grinding on the back of the caliper to get a bare minimum clearance.... 19" wheels or bigger to be safe
409CISecondGen
04-22-2012, 10:57 AM
So you put the OEM GTO Fronts on the back? Where can I read about this? And what rotors did you use that fit the parking brake?
mark21742
04-23-2012, 08:22 PM
2010 Camaro ss 14" rotors.... I cut, rebent and welded the stock GTO brake shoe and adjuster to fit the new rotors
