Generation IV Internal Engine - LS3 valve spring problems...HELP!!!please
streetknight2
03-20-2012, 09:30 AM
Ok everyone, I've got a set of off the shelf GM LS3 heads for my carburated LSX Mustang project.
Pat G spec'd me a cam and I got the TEA .660" lift valve springs as recommended. Was told to set the spring height at .050"-.080" before coil bind.
Well, that would be 1.810" to 1.830"
My problem is there's only 1.770" available. The machine shop said I'd have to cut the spring pockets, use offset valve locks (if available) or by .100" longer stem valves.
Has anyone else had this problem?
TIA
Tainted
03-20-2012, 09:35 AM
there are a couple of sponsors (and a thread very recently) that sell valve spring shims in assorted sizes to dial in your installed height.
streetknight2
03-20-2012, 09:46 AM
Thanks for the response. My problem is the spring height is Too Short with NO shims.. I need cut instead of raise.
Tainted
03-20-2012, 10:19 AM
Lol woops. Id still be willing to bet tony mama or one of the other big time lsx guys have made a thread pertaining to these ecounters. I can try searching as well
Tainted
03-20-2012, 10:33 AM
I just read your other thread. Have you asked Pat G what the best way to go for that would be? It seems the info in your prior thread concluded you could machine the base, but SDPC says not to. So you either need different valve stems (which I think theres probably an easier route) or offset locks.
Hell call TSP, or EPS and see what they reccomend.
hellbents10
03-20-2012, 01:10 PM
You could sink the valves in the heads some and use +.050 locks. Although if you are running stock rockers the stock locks seem to work better (valve rotation). Or just buy longer valves.
streetknight2
03-20-2012, 01:18 PM
Yes stock rockers. I've called around and a few have recommended using a different spring kit. Comp actually recommended their 925 springs, said they'd be about 140 on the seat at 1.780", so a little more with the 1.770" I have to work with.
Ugh
Tainted
03-20-2012, 02:42 PM
Livernois has springs rated for .660 lift, not sure on their specs though. Theres so many springs available surely you can find the right set.
streetknight2
03-20-2012, 02:44 PM
I spoke with a couple people that agree I should try a different springs
3pedals
03-20-2012, 10:16 PM
if +.050" locks are available I`d go that route. I had a couple that were .010" too tight upon assembly, and I ended up cutting the locators down that much to get the installed heights PERFECT.
Bo White
03-22-2012, 01:23 PM
The main reason why people recommend setting up the springs .050"-.080" before coil bind is not for the pressure it creates but for the stability it creates for the spring at high rpm. NHRA and NASCAR has been doing that for years.
88ls1blazer
03-22-2012, 06:09 PM
actually they are good to .690 and install at 1.805
