Nitrous Oxide - Speed density tune with nitrous??
n2ols1cam
03-20-2012, 04:03 PM
Hey guys I have a forged ls1 with ported 243 heads and a ms3 cam, I will be spraying a 300 shot at the car sometime this year. I need to get my car retuned and I was wondering if I should do a speed density tune. Would it help for nitrous? What would be the benefits of going with a speed density tune? Thanks guys!
soundengineer
03-21-2012, 11:30 AM
No power difference in speed density or a MAF tune....
2 different ways to get to the same end result.
a MAF is better at Day to Day compensation and will be more consistent at WOT
but SD has benefits too...it tends to have a crisper throttle response as you are telling it the fuel instead of the pcm looking at airflow and then calculating how much fuel it needs
unless you use a HP Tuners custom OS, you will be using the secondary VE table without the MAF(on 98-00 cars) and you will be using the low octane spark table without the MAF(all cars)
so without a Custom OS, staying with the MAF has benefits over SD.
wet shot or dry shot really makes no difference on either...
n2ols1cam
03-21-2012, 11:43 AM
Thank you for the response. so a SD tune wont hurt my car's performance on nitrous?
soundengineer
03-21-2012, 11:45 AM
nope...not one bit...
I'm a perfect example...
I cant use a MAF due to my extreme setup and I have an aftermarket pcm doing SD....
dual direct port dry shot....and not a small one ;)
n2ols1cam
03-21-2012, 11:56 AM
ok cool. i have to get my car retuned so i think going to go speed density. ive heard that the car will run a little better and have better driveablity. and plus i want to get rid of my restrictive maf. a stock pcm can handle a SD tune just fine right?
soundengineer
03-21-2012, 12:03 PM
the MAF is usually not a restriction unless you still have a stock one with a bigger TB
once you upgrade the TB you should upgrade your MAF to match
they make 100mm MAF's and 104mm Lid's ;)
the car will run the same in SD or using a MAF... its all about how good yoru tuner is...
driveability will be identical either way if tuned properly.
and yes...the stock pcm can handle a good and proper SD tune
n2ols1cam
03-21-2012, 01:09 PM
as of right now i have a slp lid with a stock maf and a 92/92 setup. so i was going to run a ftp 98mm with no maf. would you recommend going SD or go with buying a bigger maf?
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
