Predator tuneing HELP PLEASE!!!!!
Old 03-20-2012, 09:11 PM
1320BIRD's Avatar
Default Predator tuneing HELP PLEASE!!!!!
k guys I have ls1 with 4l60e trand 10 bolt 4.56 gears i bought predator tuner and it lets me make all changes and when test drive no shift to 2-3 or 3-4 ??
i change the shift points on RPM base and as well as MPH together and individualy PLEASE HELP !! WHAT AM I DOING WRONG??
OR can someone point me in a better direction?
Old 03-21-2012, 08:56 PM
1320BIRD's Avatar
Really Anyone ever have this problem ?
Old 03-22-2012, 03:06 PM
disc0monkey's Avatar
you did choose the automatic tune? is the rev limiter set lower than the shift point?
Old 03-22-2012, 03:08 PM
LS1Tech Sponsor
Mike@Diablosport's Avatar
Im guessing the MPH is set too high, it has to reach the MPH before it commands the shift.
What is the revision on the Predator?
Old 03-22-2012, 06:02 PM
1320BIRD's Avatar
ive cotacted the help line , he says i have the most updated unit,
i have tried several ways , i tried raising and lowering shift point (MPH)
i even tried changing shift point through RPM , I even tried changing Rev
limit thats totaly shuts down motor when put in gear , I was told by support help that I should take to CMR ??? i have reset parameters several times , i dont believe im confusing computer .
I used a formula for F-Body.com for trans gear ratio/ to tire size for mph infor at each geat , i will say this 1-2 shift is perfect around 6100 ??
Old 03-23-2012, 07:50 AM
LS1Tech Sponsor
Do you have the cables to connect the tool to a PC and export the tune files?
Old 03-24-2012, 08:34 AM
1320BIRD's Avatar
i would have to say if it didnt come with , most likely not , what do I need ?
