Stereo & Electronics - HELP! Wired my 2speed single electric Fan Wrong?
SIKHS 5
03-20-2012, 10:39 PM
I wired this diagram using two Tyco 75AMP relays. Im running a Taurus Electric Fan([2 speed single fan]cannot take 12v high and 12v low simultaneously), Using factory Gen III PCM outputs. Does anyone know whats wrong/how i could fix the problem?
http://i20.photobucket.com/albums/b234/Simarjit/taurusfanlayout.jpg
I've checked the wiring about 10 times now and it is wired like this and it does not seem to "work".
my relays didnt have "87A" and i assumed it was the same thing as "87"(wrongly?) - so the teal wire in the diagram goes from 87(with fan high) to 87 instead of 87A to 87. is this the culprit? if so how could i get around this having only 2 "4 pronged" relays?
What I am getting following the diagram above:
PCM LOW grounded only = [0v @ FAN LOW] [0v @ FAN HIGH]
PCM HIGH grounded only = [0v @ FAN LOW] [12v @ FAN HIGH]
PCM LOW & PCM HIGH grounded = [12v @ FAN LOW] [12v @ FAN HIGH]
What is needed:
PCM LOW grounded only = [12v @ FAN LOW] [0v @ FAN HIGH]
PCM HIGH grounded only = [0v @ FAN LOW] [0v @ FAN HIGH]
PCM LOW & PCM HIGH grounded = [0v @ FAN LOW] [12v @ FAN HIGH]
WhiteBird00
03-21-2012, 07:03 AM
You need to get yourself a 5-prong relay. The 87 and 87A terminals do opposite functions. 87 is active only when the relay is energized (NO - Normally open) and 87A is active when the relay is at rest (NC - normally closed). Without using the NC terminal 87A, you aren't getting any pass through power from the fan high relay to the fan low relay.
