4L60E transmission question
I have a 5.3L that came out of a 2002 GMC Sierra thats going into my Cutlass & I'm looking for a 4L60E transmission to mate with it. I know with some cars the transmission have to be from a specific year so will any year 4L60E work or do I need a trans from a specific year to work with my engine & wiring? I see a few of them for sale here where I live but I do not want to spend that amount of cash for something that I will not be able to use so could you guys please help me out & let me know which trans I can & can't use. Thanks!!
The following users liked this post:
unclecowboy (10-06-2023)
A 4L60e from a 98-02 V8 f-body, 04-06 GTO, 99-07 GM 2WD V8 1500 trucks and SUVs will work. Vans are iffy. You have to make sure it had a 5.3 V8. They used a lot of 5.7 vortec motors in the Vans till the late 2000s.
If you decide you would like a built 4L60e let me know. I'll work up a quote for you.
I just went through this, Like said above make sure the trans is from something that had the LS engine in it. Pretty much all the 4l60e that had an LS motor will work, tahoe, suburban, pickups (ext cab and reg cab will work either way), camaro and T/A all 2wd of course. The wiring harness part makes the selection a little more specific. Cars had the park neutral switch up by shifter and it would not be in the harness, and trucks had them on the transmission this will be in the harness. In I believe 2003 trucks changed the connector on this switch but the trans itself is the same you would just need to swap the switch, which is another about $40. good luck
Ok guys I'm still on a tranny search and I think I found one. I'm going to check out tonight if the guy is available. It looks very similar to the one in this thread https://ls1tech.com/forums/12585250-post5.html but I cant tell if it has PWM on the pump & he wont be at the trans until later tonight. I hope this is the correct trans because I really need it. Pics below
It is the two piece tranny so I'm guessing this is the one I need & Here are a couple pics if the trans. tell me what you think!
Here are the pics of the trans. The park neutral switch is on the transmission so that means this one came out of a truck, right? if this is the correct trans that would be perfect since my engine & harness are from a truck.
You are really close with your trans. Since it is a 3-piece tranny (bellhousing, body, tailshaft), you could swap the bellhousing with a V8 one. Internally, they are all the same, with the same gear ratios. Your bellhousing is the 'narrow' housing from some V6 applications.
The biggest problem with using these mismatched from the motor they came behind is the torque converter. Any 4L60E/700R-4 converter will fit the trans, but it won't necessarily fit your flexplate. With older converters, you will need a flexplate spacer and will also have to oval out your flexplate bolt holes to match the smaller converter pattern.
However, if you get a LS specific converter, it is physically bigger (not by much) so that is protrudes enough to fit your flexplate, and has the correct bolt pattern. Example: Hughes GM22LTOW converter fits the trans, not the flexplate. Hughes GM22ELTOW fits everything fine, because it's an LS specific converter. (ask me how I know...)
convert my 700r4 connector to a 4l60e>?
I just got a wiring harness from a frend that he no longer needed and when its all said and done i want to back my lq4 with a 4l60e but the harness i got has a connector for a 700r4? can any one help me or give me a number to some shop that can re wire it?
Kyle
socal101703@yahoo.com
Kyle
Eliminate computer on a 4L60E-4L65E or a 4L80E FM box
Kyle
Kyle
Please contact me for a professional consultation regarding your needs. We are happy to provide you with references both here in the United States and Internationally. Be sure to check out our website at maddogtransmissions.com
Hear what our customers and fans say on our Facebook Page at www.facebook.com/maddogtransmissions
We also accept orders over the phone. Be sure to contact us and we will recommend the correct transmission for your application. For your convenience, we accept PayPal and all major credit and debit cards.
If you prefer, we can call you personally, just e-mail us your phone number.
All our transmissions are very strong and reliable, and can be used for everyday driving. Extended warranties are also available.
Thank You,
"Mad Dog" Lou
Mad Dog Transmissions
Phone 770-781-0949
Fax 770-781-0969
Web: www.maddogtransmissions.com
Facebook: www.facebook.com/maddogtransmissions
Twitter: www.twitter.com/maddoglou
YouTube: www.youtube.com/maddogtransmissions
Read this if you need further clarification: http://www.novak-adapt.com/knowledge/4l60e.htm also the last paragraph of this: http://transmissiongarage.com/About/4l60-e_tech.php
*Note* I am not a trans guru. I personally despise auto transmissions. If my info is misleading or slightly incorrect, please forgive me, but know that I'm not just talking out of my butt here.
