Aeromotive fuel regulator question need a little info
Old 03-21-2012, 11:40 PM
GASH1313's Avatar
Default Aeromotive fuel regulator question need a little info
I'm runnig an Aeromotive A1000 Regulator with a fuel pressure gauge on the regulator and I'm not showing pressure. I don' have the vacume line hooked up yet, Is that why it's not showing pressure? I have fuel and the car is running.
Old 03-22-2012, 07:54 AM
Old Geezer's Avatar
The vac line won't make the gauge flaky.
The vac line is used if you have the IFR tuned to a single value.
If the IFR is a calculated/rising value, the vac line port is left open.
Sounds like a flaky gauge. Is it one of the silver dollar sized units??
Old 03-22-2012, 09:26 PM
GASH1313's Avatar
The guage is showing pressure now after fixing leaks, but no I show 42lbs at idle and pressure drop when you give it throttle! I do need new injector o rings.
