New Guy on LS1 Tech
New Guy on LS1 Tech
I've been reading off of this forum for a bit now and I just wanted to say hello to everyone and introduce myself.
Name is Tony, I live in MN north of Minneapolis.
I joined this forum because I'm starting to build an LS1 for a swap into a smaller car; I have a few in mind, the primary ones that I would like to get would either be a 240z or a 3rd gen rx7. Neither of which are easy to find or cheap, but I figured I'd start to build the motor while I save up for a solid shell.
The only power adder I'm looking at for this motor is an upgraded cam, something around a 224 with a .581 lift (I'd like it to be mild for everyday driving) If someone has a better cam in mind to recommend please do so. Otherwise essentially stock output with beefed up internals in-case I get bored and want to throw nitrous at if for the days I make it out to a track.
I apologize now if I ask a stupid question, or something that is more "common knowledge" as I'm really just starting this build and trying to learn all I can before I start purchasing more parts.
I was able to obtain a block with low miles for my rebuild (late generation corvette block) with the crank (both in excellent condition); some 853 casting heads which I plan to have new guides put in and I will replace the valves/springs with something stronger than stock, and an LS1 intake manifold.
Looking forward to learning more from this forum in the upcoming months,
Thanks for reading!
Tony
Thanks for reading!
Tony
