Cadillac CTS-V - HP Tuners info-dyno tune
View Full Version : HP Tuners info-dyno tune
ObfuscatedV
03-22-2012, 08:56 AM
Having the V dyno tuned today. Will be done using HP Tuners. Is there anything along the electrical/fuse side that should be disconnected beforehand? Such as Onstar/Nav? I want to make sure I dont lock out the pcm, etc (if thats even possible).
Twitch1
03-22-2012, 09:45 AM
You don't need to unplug anything. Just make sure EVERYTHING is turned off (lights, radio, doors closed) when they flash the computer. If your battery is in good shape, you should have no problems.
ObfuscatedV
03-22-2012, 11:34 AM
Appreciate the feedback! Thanks
liqidvenom
03-22-2012, 10:06 PM
I did what Twitch mentioned and sometimes i have to pull the radio fuse... but hopefully you dont need to do that
GulfM3
03-22-2012, 10:55 PM
Twitch nailed it, I've flashed mine a dozen or more times without an issue. Keep everything off and you will be fine. Another thing you might want to watch is when flashing the ECU the laptop needs to be running on battery power, having it plugged in can cause ground offset and screw with the flash.
JJSimon904
03-23-2012, 01:30 PM
I've never had a problem leaving lights on or doors open with HP Tuners...hundreds of flashes over the years. The one thing I've never tried is flashing with the laptop plugged in as the others said. Its a big fat warning and although you will probably be fine more ofthen than not, I've never tried it..haha.
