Truck intake manifold egr block off
Old 03-22-2012, 11:36 AM
groundczero's Avatar
Default Truck intake manifold egr block off
I got a 2002 4.8 truck intake manifold.
It has a whole in the passenger side which looks like were the egr stuff goes. Was wondering if there is a block off plate I can get for this.
Old 03-22-2012, 01:50 PM
1936 LS1's Avatar
Bought mine from WS6store.com. About $25. Part #12558346
Also available from GM.
Old 03-22-2012, 03:19 PM
bczee's Avatar
Are the Truck configured like the Car LS1 ones ? If so.. then yes you could use that GM number to order the GM Plug. I just ordered it from the local GM Dealer.
If not use a rubber freeze plug.
BC
Old 03-22-2012, 03:22 PM
1936 LS1's Avatar
Exact same part. There are several threads on here and other site regarding this.
Old 03-22-2012, 06:14 PM
patooyee's Avatar
If you are referring to the big port in the back of the manifold with the push-lock fitting I found that the smooth shank of a 1/2" bolt fits perfectly in there and is held in place by the fitting. I just cut the threads off of the bolt. I know, its butch, but it works.
J. J.
Old 03-22-2012, 06:51 PM
1936 LS1's Avatar
It's on the right front of the intake see this link -->>>
https://ls1tech.com/forums/conversio...ntake-egr.html
Old 03-22-2012, 06:56 PM
patooyee's Avatar
I apologize. That is not the hole I speak of. My intake did not have that.
J. J.
Old 03-22-2012, 06:58 PM
dynodanmanda79's Avatar
Yep, Same exact setup and part number as the LS1 intakes
Quick Reply: Truck intake manifold egr block off
