Chevrolet Camaro 1967-2002 - 98 z28 with 2000 ls1
leem23
03-22-2012, 01:24 PM
I am trying to figure out how to get my car running. I put my built ls1 from a 2000 ws6 in a 98 camRo z28. I need to know what wiring harness i should(98or00) use as well as which pcm? Also do i need to swap out any sensors if i use my 2000 wiring harness? All input is appreciated.
Camaro98Z/28
03-25-2012, 09:51 AM
2000 should be a drop in swap. Use your 98 as thats year specific to the 98 pcm cluster and fuel pump.
leem23
03-25-2012, 12:32 PM
Ok cool thank you
mjs1012
03-27-2012, 01:34 PM
I'm actually doing the same swap. Just take all the sensors off the 98 and use them in the 00 motor and keep the 98 wire harness.
MrElectric03
03-27-2012, 09:45 PM
Well as stated 98 harness needs a 98 pcm. The only sensor I know for sure is different is the oil pressure sensor, the 98 is a two pin and 99+ is one pin.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
