Carbureted LSX forum - What do you use for a water pump?
streetknight2
03-22-2012, 05:20 PM
I'm doing a carb'd fox body that'll be a track only car. Wondering what I should use. I only need an alternator and water pump for accessories.
Thanks for any info.
3pedals
03-22-2012, 08:07 PM
I used the oem truck pump with my first setup, but I now have a Moroso electric setup.
I should have got the Meziere race pump as it requires less extra plumbing, which is $$$
thirdgenbum
03-22-2012, 08:49 PM
i'm using a fbody pump and alternator in my thirdgen swap, nothing else.
http://i86.photobucket.com/albums/k108/mw66nova/104_0795.jpg
ZONES89RS
03-22-2012, 09:57 PM
If you have a cowl, the cheap option is the truck pump and bracket combo, the f car setup as you can tell saves room up high and looks cleaner. I have custom brackets in my RS and truck setups on my 94 gmc, 86 TA and the 85 TA that I am working in now.
Prorac1
03-23-2012, 01:57 PM
I am using the autozone replacement pump for the Corvette/Fbody which has the extra deep pulley on it to work for both applications. This helps me make the custom spacing required when using a front engine plate, which spaces the waterpump out an extra quarter of an inch. Hope this helps, Eric L
johnyrrr
03-25-2012, 07:07 AM
Prorac do you have a pic of this pump and how the belt rides on the pully? I have truck pump an pully but would like a cleaner setup and not have the altenator as high as my carb.
Prorac1
03-26-2012, 08:18 AM
I do not have a pic. But this would probably be to short to fit on a truck alternator spacing. Its meant for the camaro/corvette spacing.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
