lonnies stage 3 street kit boost and e85 limits?
Old 03-22-2012, 07:44 PM
TermnEatr's Avatar
Default lonnies stage 3 street kit boost and e85 limits?
Im thinking of going the e85 route with my build I have 80lb injectors and will have the lonnies stage 3 street kit with a maxed out d1 on a 370ci how much power will the 80s and the kit handle on e85? _______
Old 03-22-2012, 09:38 PM
LS1TECH Sponsor
Lonnies Performance's Avatar
The 80's will max out at approx 750-775rwhp on E85.
My standard dual pump kit will support this with a little safety factor left over.
Your D1 will likely be maxed out as well at this power level.
Please call to discuss your combination in more detail to be sure you buy the correct parts the first time. Personally I would start with bigger injectors, depending on your power goals.
