Generation IV External Engine - what are the best 2006 ls2 gto upgrades for more horse power?
goatseatanything22
03-22-2012, 10:54 PM
i am looking to find out the best upgrades for my ls2 gto, w/o supercharging or nitrous, to get a lot more horse power from my car please help me
FryZ71
03-23-2012, 09:21 AM
Don't know your budget, but an over the radiator (OTR) intake like the Svede or Vararam, long tube headers, and a tune should be your first power mods. Cat-backs are for sound, mostly...worth about 5HP tops. If your suspenson is stock, you'll need to address the saggy rear springs, front radius rod bushings and strut mounts. Get all that done and then you can get into a cam, heads, etc.
Check out the GTO-specific section for more info.
goatseatanything22
03-23-2012, 11:16 AM
budget is pretty lose i would say im just looking for the most power without going into the engine. i have k/n CAI full SLP exhaust besides headers which i already planned on getting but i was curious and TB and Intake manifolds????
goatseatanything22
03-23-2012, 11:17 AM
possibly heads but im not sure if you have to pull the motor for them??
FryZ71
03-23-2012, 11:42 AM
You could have the TB and intake ported for small gains. Heads would be a waste w/out a cam...besides, plenty of guys make good power w/ a cam and the stock 243s. In your OP you said you want "to get alot more HP from my car"...you don't want N2O or FI, then you're going to have to cam it. Just not that much power to free up w/ just bolt-ons.
litle88
03-23-2012, 02:24 PM
Most hp means Lt's, Tfs heads, fast 102, vararam intake ( That k&n sucks), nice cam like a vrx5 or vindicator or g6x3? cam or any other lg cam and most importantly a tune.
Just my .2 anything else and you'll be wasting time and money.
goatseatanything22
03-24-2012, 11:54 PM
what is the best cam for the car w/o exsesive lobe i dont want it to sound rediculous
gs462
03-25-2012, 01:18 AM
You have to decide if you're going to keep the stock heads, you will need new springs with a new cam and possibly a retune, Get a plan together and call one of the sponsoring vendors like TSP they will guide you to what is best.
goatseatanything22
03-26-2012, 09:49 AM
I also don't want to risk screwing something up in the engine if I did cam it what else would need to be upgraded??
litle88
03-26-2012, 02:26 PM
If your doing a cam IMHO I would do a c5r chain a melling oil pump a set of chromoly pushrods and a good set of springs matched for your cam. Just my .2
Dyno Junkie
03-27-2012, 06:28 AM
LS3 heads and inlet manifold is the most power you will make before a cam change.
fatmat80
04-11-2012, 12:35 PM
OP you have gotten some good advice. Most power is probably going to be nitrous dollar for dollar. However if you are not into forced induction then a set of good flowing heads(TFS/AFR/PRC/ETP/TEA...)and a matching cam are the best way to go. Ditching the ls2 manifold would not be a bad idea either..good luck...
Storm Trooper
04-11-2012, 03:06 PM
^Correct
