Generation IV External Engine - IS THIS A GOOD GROUND ??? ((( pic )))
Circa307
03-23-2012, 12:10 AM
01 z06 with a iron block in it now. the iron block has no ground spots for this ground strap, so i grounded it it on the back of the bellhousing. The bellhouseing bolt goes into the block so i figured it would have pletty of ground.
FYI it is the ground that is connected to the oil temp sensor pigtail.
thanks in advance.
http://i801.photobucket.com/albums/yy297/Circa307/c05e9c7f.jpg
S10xGN
03-23-2012, 07:19 PM
I hope that's not the only ground "strap" on your engine! If it is, you'll torch it instantly the first time you turn the key to "start"...
DietCoke
03-23-2012, 08:24 PM
PCM ground to the back of the head. Harness ground to the front of the head. Heavy ground from the side of the engine to chassis at a minimum (4ga... mine goes from the engine mount)
LS1MCSS
03-24-2012, 09:36 PM
thanks in advance.
I hope you were planing on using a shorter bolt. That wire has to be tight against the head. It won't work the way it is.
Circa307
03-25-2012, 12:00 AM
lol yes it will be tightend down lol. thanks for looking out for me tho. A c5 has many engine grounds. but when u swap in a iron block, you need to make (drill and tap) grounds or get creative. For some reason a iron block doesnt have the same ground locations as a ls1 ls6
LS1MCSS
03-29-2012, 03:09 PM
lol yes it will be tightend down lol. thanks for looking out for me tho. A c5 has many engine grounds. but when u swap in a iron block, you need to make (drill and tap) grounds or get creative. For some reason a iron block doesnt have the same ground locations as a ls1 ls6They moved them because the irom blocks started out as a truck motor with the pcm on the drivers side near the front. It would have been nice to put all of them on one bolt, though. Instead they two or three different places.
93camaro_zzz
03-29-2012, 03:27 PM
Thats not a bad spot, as long as it is a clean and tight ground, but really you can put the ground anywhere you want, you just have to splice the wire and make it a little longer. If you swapped the engine on that vette, I would imagine you would know how to do that. lol
That looks like the ground that is at the rear of the drivers valve cover on an LS1. Am I right?
Circa307
03-29-2012, 08:31 PM
http://i801.photobucket.com/albums/yy297/Circa307/4415357231_ba21d90ddd_b.jpg
^^^ this ground
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
