good ground ????
good ground ????
01 z06 with a iron block in it now. the iron block has no ground spots for this ground strap, so i grounded it it on the back of the bellhousing. The bellhouseing bolt goes into the block so i figured it would have pletty of ground.
FYI it is the ground that is connected to the oil temp sensor pigtail.
thanks in advance.
thanks in advance.
