Fueling & Injection - How do you make a LS1 fuel gauge read 0-90 ohms????
BlackWS666
03-23-2012, 08:02 AM
I got a nasty nate fuel cell and everything all hooked up, and to my suprise the guy before me used a after market gauge to read his fuel level. So i searched for about a hour with no results found yet. I seen how easy it is to go from ls1-lt1 but no lt1-ls1. I was just curious if anyone has ever heard of this being done, or knows where you could buy a circuit for the conversion. Thanks in advance gents!
trik396
03-31-2012, 11:35 AM
I thought GM used 0-90ohm senders already???
Ollie8974
03-31-2012, 02:17 PM
GM changed the OHM rating of the fuel level sender. I don't know what year the change was made. I do know the 4th gen. sender is 40 to 240 OHM's.
Are you using the 4th gen sender?
I have this vendor bookmarked. I have not used him.
http://www.tristarrradiator.com/
tt383lt1
03-31-2012, 02:27 PM
i have a 94 z and i installed a 0/ 90 ohm gauge with the stock level unit and it works back word full is empy and empy is full but it works good i think i have to switch the two wires on the level
BlackWS666
03-31-2012, 06:17 PM
Well the 0-90 was only readying about 1/8 tank at 3/4 full, so i had to do something. I ordered a new unit for the tank from nasty and tryed it last night worked, but full was reading about 3/4 full, so i dunno what to think. Guess i will have to bustout the ohm meter and see if its reading correctly.
BlackWS666
05-01-2012, 08:08 PM
bump for this. Anyone know how to change the stock gauge to read 0-90 ohms?
Ollie8974
05-02-2012, 08:47 AM
I don't know if it can be changed might have to replace the gauge.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
