Pontiac Firebird 1967-2002 - Door Panel Staples
ds2011
03-23-2012, 09:23 AM
I know there is a sticky on this subject but I just wanted to ask a quick follow up since I'll be doing this repair soon.
- What's the best thing to use to replace the staples in the door panel?
- Nuts and bolts?? If so - what size?
- A certain gauge wire?
Something else??
Thanks!!!!!
PontiacFan
03-23-2012, 10:18 AM
Sticky, up top in the Firebird forum, ..., ^
http://ls1tech.com/forums/pontiac-firebird-1967-2002/440767-cracked-interior-door-panel-dont-quote-pics.html
There are links in there to help show the info you are looking for.
ds2011
03-23-2012, 12:28 PM
Yup. Thanks. I saw that. I was trying to avoid reading through every single post and was just trying to find out what to use to replace the staples.
Can't I just reuse the existing staples and elongate the holes??? That would relive the stress that causes the crack would it not??
Snake_Skinner
03-23-2012, 03:11 PM
I just used nuts and bolts, it worked but I don't really prefer it. Actually my main complaint isn't the nut/bolts but more the crack is still there after the fix, when you fix it make sure and use something to pull the crack together(not glue). There's a write up where a guy used like some sort of fishing line or something and pulled the crack shut and you couldn't even tell the crack was there, that's what you want to accomplish if you've already got a crack, if not then ya elongating might work for ya. The staples might not let the panel flex so just make sure you use something that's going to allow the panel to expand and contract, that's the main thing.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
