Fueling & Injection - Drop in 340
View Full Version : Drop in 340
rad23
03-23-2012, 10:11 AM
I GOT A AERO 340, TOUGHT IT WAS GONNA COME WITH A WIRING HARNESS AND ALL THAT JAZZ BUT JUST CAME WITH A BLACK/ RED WIRE CONNECTER LIKE I HAVE TO JUST SPLICE OR TAP TO STOCK WIRES. AM I MISSING A PIECE, WIRES, ECT. OR IS IT REALLY THAT SIMPLE? is there a vid on this i checked out the wal 255 so im sure it just like that (also came with fuel tube 6in or so, 2 hose fitting, pump, sock)
RX-Matt
03-23-2012, 03:46 PM
If this pump is for your 99 Camaro you will have to modify your bucket, and cut and splice wires to get the Aeromotive 340 to fit. Even then it will not work "properly" as the factory bucket is designed with a venturi system.
Our FPA-001 is a direct replacement and comes with EVERYTHING you need for installation. It can be ordered direct or from many many dealers!
http://www.racetronix.biz/itemdesc.asp?ic=FPA-001&eq=&Tp=
http://www.racetronix.biz/mmWEBSTORE/Images/FPA-001.jpg
Lonnies Performance
03-24-2012, 09:03 AM
Not to mention that the connector on the top of the sender may melt due to the larger pumps current draw.
You really need upgraded wiring (both inside & outside of the tank) to run that pump.
