philaeagle51
03-23-2012, 06:11 PM
my stock 2002 camaro door speakers are blown. I was told these would fit and be an easy install (no modification). is that true? Alpine SPS 610. thanks
Capricio
03-23-2012, 08:41 PM
If you are content to downgrade from a component set to a pair of two-ways, and give up one channel of amplified power on each speaker, then yes, they will work and probably install fairly easily.
Blownbayou
03-23-2012, 09:24 PM
just get infinitys and wire it up like a component..... very easy to separate the tweeter from the woofer and will wire up like it should be.
later
