Grand prix LS1 build
Old 03-24-2012, 02:18 AM
85GPLEf41's Avatar
Default Grand prix LS1 build
I finally test fitted my ls1 on my 85 GP... I used the Transdapt 4595 1in setback plates after grinding on them a bit, ground down a couple bolts that were hitting the webbing on the block and bolted in the factory clamshells.. Only issue i still have is the alternator not fitting in but i'm going to install the hood and see what clearance i have. If good then i'm ordering the speedway high mount alt kit, some other alternative.. Anyways here are some pics
Old 03-28-2012, 04:00 AM
85GPLEf41's Avatar
Test fitted some f body cats factory, drivers side seems to fit good BUT passenger side hits the floorboard... haven't installed the trans yet which could affect the clearance, i found out by googling up the numbers it is actually a 4L65E. Guy i bought it from said it was a 4l60, According to the numbers, it's a 2004 4L65E from a 4x4. He included a 2wd tailshaft housing and a dipstick. Also he rebuilt it with a "power pack clutches, beast sunshell, Corvette servo and a 2k stall converter.... What mods would have to be done to the stock 99 LS1 computer to run this trans? It originally came with a auto trans. Also found a T56 from a 01 Camaro for 1K, Would it be better to pick it up instead? I really would love to row my own gears But i would have to find that $$ somewhere...
Old 04-22-2012, 11:20 AM
veltboy618's Avatar
any updates?
Old 04-22-2012, 12:07 PM
V8Rumble's Avatar
Cool
VERY cool build!! I've actually thought about doing one of these, it's going to be interesting to see how this one comes together!
Old 04-24-2012, 02:08 AM
85GPLEf41's Avatar
NO updates yet seeing as I'm working all the time will post some trans crossmember mods soon and hoping you guys can help.. And thanks for the compliments V8rumble i've always liked Pontiac rides! Yours look SWEET!
Old 04-24-2012, 11:21 PM
85GPLEf41's Avatar
Finally got my trans crossmember done.... Hope so! I did a trans crossmember 2004r mod..
welded in new c channel
but was off on wrong angle..
redid the trans mount now..so i cut it off and redid it..
so angled the the crossmember and it seems to work now..
trans weight is all on it now.. and clearance is way better now..
Old 04-25-2012, 09:32 AM
jmd
jmd's Avatar
Looking good. I appreciate your documentation since my 87 will go LS / Auto some day.
What oil pan is on the engine and how much distance is there up to the engine cradle crossmember? I want to test fit a batwing for some reason.
Old 04-26-2012, 12:32 AM
85GPLEf41's Avatar
I used the CTS-V oil pan, as for the clearance between the oil pan and crossmember it's pretty good and it doesn't hang too low from the cradle. I have about at least 1/2in around the oil pan sump.
Also here are a few more pics of the high mount alt kit form Speedway,
The alt fits good now but the "cooling duct" hits the plug wire and the sensor harness is too close as well... I was told to get a truck alt and that would solve that issue. Gonna test one out and see. Gonna notch my heater box soon for the passenger side coil packs next....any ideas??
Old 04-26-2012, 09:32 AM
V8Rumble's Avatar
I have a truck alternator that you can use for test-fitting, should save you the hassle of buying one. Besides, it makes for a good excuse to meet each other & have a beer...
Old 04-28-2012, 03:26 AM
85GPLEf41's Avatar
I'm down for a test fitting session, of course beer is required to make it complete, give's me a chance to check out your beast!!
Old 04-30-2012, 12:45 AM
85GPLEf41's Avatar
More work done this weekend, My buddy Nate cam over and helped notch and fiberglass my heater box for coil clearance. I cleaned, painted and modified my 8.5 for the rear LS1 disc brakes upgrade.. Some pics of the box notch just gotta paint it now.
The rearend got new bearings and seals as well.
Quick Reply: Grand prix LS1 build
