Paint & Body Work - Painting LS6 Intake
I8UR4RD
03-24-2012, 05:24 PM
Hi, guys. I have decided to paint my intake and just figured I would go over what I am doing to make it happen, just in case it turns out decent. I blew the stock LS1 and I was afraid the intake was going to ugly up the new motors look so......I started with some 180 grit all the way around, and first off realized why I do not miss body work and prep. The valleys and circles take some real elbow grease. I did it in stages. About two valleys a night. I should be painting here soon now that the prep is done. I will be using Promoter, and Primer, and gloss black engine paint. Oreily auto parts shit. rattle can baby. I have heard bad things about clearing them. Thinking about hitting it with a couple coats anyways.
Here are a few pics
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0039.jpg
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0040.jpg
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0043.jpg
fucter
03-24-2012, 05:55 PM
Interested in your results, and good luck man!
I8UR4RD
03-24-2012, 07:40 PM
well getting in all the tiny nooks and crannies is quite the chore. i mean you cant get your fingers or any type of sander in there, but i did the best i could. i figured as long as i rough/scuff up the surface enough to get it to adhere it should be fine. I just got done blowing it off with the air compressor, and some of the mounds of plastic dust were somehow stuck in there so i had to spray it off with the high pressure hose, re tape it up and i have it in the oven now on the warm setting which i think is around 150-180 degrees drying off. I am going to start with the priming and painting tomorrow. gunna do one light coat then one slightly heavier coat of the promoter and the primer both. then for 3-4 coats of the black. I think it is going to look really nice in addition to the shiny new AES 390, black anodized battery cover, and red fuel rail covers....all my procharger pipes have been powdercoated gloss black too and they shine like the car does when its clean. the only thing under the hood that will not be black is the trans am fuel rail covers and the stainless steel fuel lines. its not only to go fast, but it will look good doing it. i get tired of looking under LS hoods and seeing pure nasty messy shit. the wire mod will be the next.
05lactruck
03-24-2012, 11:02 PM
Looks like you have the right idea for the prepping. Should look good when your done
05lactruck
03-24-2012, 11:03 PM
I would sand the primer with 600 before you spray the black. It will look real slick
I8UR4RD
03-25-2012, 04:35 PM
oh yeah def going to wet sand the primer. thats a given...however i am only going to go as high as 300 with the paper because if its too smooth the paint will have a harder time adhering, and from the naked eye the difference would not be noticeable. i have had a few people tell me that they made it too smooth, and that if they would have left the surface a little rougher they think it would have adhered better. we will see. thanks for the great tip though! fixing to start now ......after some ice cream and buds.
02WS6speed
03-25-2012, 07:02 PM
If you are going straight to basecoat after sanding your primer with 300 you will definately see the sand scratches after its all said and done. If you plan on spraying a sealer and then base you might get away with it but even then, most sealers call for 400 grit or finer. typically its 400 before sealer and 600-800 before basecoat.
I8UR4RD
03-31-2012, 05:33 PM
naah. no sealer. I sanded it with the 320 and it is looking really smooth. I can see minimal scratch marks on it, but I think once the black is on, plus the fact that it has metallic in in and I plan on 3-4 light coats, it will not be visible unless you get on it with a magnifying glass. I just wet sanded the primer after 1 light coat and then 2 more and sanded once again. Had good light and humidity today. Just blew it off with the air compressor and saw what I was working with. I am doing this with minimal effort just in my spare time, either way I am quite sure it will look waaay better than it did even if i did not pay for a pro to do it, or attempt the powder coating. Waiting for her to dry now, before a final assessment. may go ahead and move onto paint, and throw on 2 lights clear coats. Although I have heard bad things about the clear, I guess i like to find out for myself. The adhesion promoter really did its job with the primer, the hardest place to spray was in between the low valleys on the very side where you cannot get your fingers....the primer will pool right there and flake off, and I am debating spraying it in there because of the pooling effect creating such a thick primer coat that it will have detrimental effects on the overall look, the only thing that really matters are the top parts of the valleys. here are a few new snap shots.
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0058.jpg
now onto paint which is a mix of gloss black and metallic. 3 coats first light progressively getting heavier done over a one hour span every 20-25 minutes.
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0062.jpg
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0061.jpg
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0060.jpg
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0057.jpg
I8UR4RD
04-01-2012, 01:42 PM
i still have a few light spots but dont wanna get to anxious. taking my time. the first coat went on really well, and I am super excited to start seeing all this pay off. I think my fav part will be putting on the clear. i bought the high gloss shiney shit. will prob crack off in a year, but it will look nice for the time being. one day IM sure this will be for sale and I will upgrade to a fast 90 90 combo that comes done outta the box. but for now this will most certainly suffice for my purposes.
I8UR4RD
04-01-2012, 02:53 PM
final coat before clear.
http://i262.photobucket.com/albums/ii107/kief4diamonds/PICT0063.jpg
05lactruck
04-01-2012, 05:47 PM
Looks good
christiandoy
04-09-2012, 08:22 PM
Wow i'm totally doing that.
christiandoy
04-09-2012, 08:26 PM
cant get over at how good this looks
christiandoy
Wow!!!!!
I8UR4RD
04-16-2012, 10:16 PM
yeah. I finally finished doing the clear, which really made it no shinier than it was to me, but seemed to make it smoother to the touch. I let it cure for about a week in a box in my room ( nothing like coming home to some nice fumes) and took some car Polish and a drill driven polishing pad and ran that over it a few times, and I am really excited to see it on top of a new motor with stainless steel lines, new fuel rails,and red or black fuel rail covers with black or silver lettering. It was a fun project, now I just need something else to do, thinking about having the valvecovers powder coated once I find out whether or not we can use them. But thanks alot guys.
I will post pics of it on here around august september along with other dressup items.
