Knick in Oil Galley. Is this block salvagable?
Old 03-25-2012, 07:28 AM
godlyxdan's Avatar
Default Knick in Oil Galley. Is this block salvagable?
Pulled the bottom end out of this motor last night and found that it had a rod snapped in cylinder 7. Looks like all it did is ruin the windage tray but it also smacked this oil passage. After a good Epoxy job would this be able to be run?
Motor is an 05 LM7 Iron 5.3
Attached Thumbnails Knick in Oil Galley. Is this block salvagable?-imag0035.jpg   Knick in Oil Galley. Is this block salvagable?-imag0036.jpg
Old 03-25-2012, 01:30 PM
gjohnsonws6's Avatar
Is there a hole in it or just scraped and dented? The bottom of the bore is distorted and will need to be smoothed out.
Old 03-25-2012, 04:27 PM
underacheiver's Avatar
Cant really tell but looks like it may be pretty weak now you have any access to welding machine? I dont know how epoxy would hold up to the heat cycles.
Old 03-29-2012, 08:25 AM
godlyxdan's Avatar
Im aware of the problems with the bore, im having the motor bored to 3.900 anyways so i was planning on having that cleaned up then
The hole goes all the way through but it doesnt look like the oil passage is sealed off. My dad is a professional welder (30+ years) and he has done multiple iron block motors. So as long as it can be done he can do it. his first guess was to try epoxy or something first cause he knows the risks of welding a cast iron block. So thats why i came to you guys
Old 03-29-2012, 06:57 PM
kenp's Avatar
Why not braze it?
Old 03-29-2012, 07:32 PM
S10xGN's Avatar
Nickel rod with some preheat will fix it for good, do this before the bore job.
Old 03-29-2012, 07:40 PM
mchdg86's Avatar
Just curious but why nickel rod instead of 7018 for cast iron?
Old 03-29-2012, 07:53 PM
S10xGN's Avatar
Ya know? I really couldn't say with certainty... Using nickel rod "back in the day" to weld steel flanges to cast iron manifolds was the accepted way, but that was 30 years ago and methods have likely changed since then. In fact, I've done some checking and it seems MIG works pretty good, especially for a low-stress weld like an oil gallery that doesn't require machining.
Old 04-03-2012, 02:14 PM
godlyxdan's Avatar
thanks for all the advice guys, just wanted to let you know the block has been fixed, it welded up just fine!!
The following users liked this post:
LSX_Burb (03-08-2021)
Old 03-08-2021, 11:03 PM
LSX_Burb's Avatar
I know I'm digging up an old thread, but I'm in a similar situation with a LQ4 block I bought. Did the weld hold up and last?
Old 03-08-2021, 11:15 PM
Received 3,021 Likes on 2,352 Posts
OP was last here last December. He MIGHT catch this and reply.
Usually using nickel rod on cast iron holds up pretty well as it conforms very well with cast iron.
LSX_Burb (03-09-2021)
Old 03-09-2021, 07:33 AM
LSX_Burb's Avatar
I've also heard good things on Muggy Weld 77 rods as well. My block has a small hole in the oil galley from a broken rod, and I'm debating on having it fixed or finding another block. I want something for longevity that wont give me issues.
Old 03-09-2021, 07:38 AM
LSX_Burb's Avatar
I've heard good things about Muggy Weld 77 rods with cast iron as well as nickel rods. I have a LQ4 block that has a small hole in the oil galley from a broken rod. I'm debating on having it fixed or just getting another block to build. My end goal is a 6.0 bored .065" to make it a 6.2 with forged rods and pistons to eventually run boost down the road. I'm just not sure how I feel about having the block fixed to have potential oiling issues later if something were to crack or give from the repair.
Old 03-09-2021, 07:39 AM
LSX_Burb's Avatar
Old 03-10-2021, 12:20 PM
00pooterSS's Avatar
You'll have up to 80 ish psi pushing against epoxy trying to push it off of the rail. If you were sealing the rail from the inside with epoxy that would be a different story.
Picture how car tires are patched from the inside and the pressure actually presses against the patch pressing it in place. You'll have the opposite scenario going on here if epoxied from the outside and I don't see epoxy having a chance in hell at standing up against near 80 psi on the outside of a pressurized "pipe"
There's my .02 cents, you may want to rethink using epoxy and trusting it to hold that much pressure
Old 03-11-2021, 07:34 AM
LSX_Burb's Avatar
The pressure is what I am mainly concerned about. I didnt mention using epoxy though, I was referring to a welding rod made for cast iron. That is a really good explanation of how to look at it. I bought the long block from a salvage yard for 400, and they are willing to refund it. I found a short block with no problems for 700 that I'm going to pick up Saturday instead. It's an 03 block but he is including a set of gen 4 rods with it.
The following 2 users liked this post by LSX_Burb:
00pooterSS (03-11-2021), G Atsma (03-11-2021)
Old 03-11-2021, 12:21 PM
00pooterSS's Avatar
**** I responded to the original poster. I didn't realize it was an old thread and that you were asking questions.
The following 2 users liked this post by 00pooterSS:
G Atsma (03-11-2021), LSX_Burb (03-11-2021)
Old 03-11-2021, 03:44 PM
LSX_Burb's Avatar
No worries LOL. I was wondering where you got epoxy from, now I know.
00pooterSS (03-18-2021), G Atsma (03-11-2021)
Quick Reply: Knick in Oil Galley. Is this block salvagable?
