Drag Racing Tech - Another 10 bolt question
hot93rod
03-25-2012, 09:12 AM
Ok, i have a semi beefed up stock 10 bolt (rear end girdle, and detroit tru trac gears). My car was last dyno'd at around 350-360rwhp and 380tq (roughly). I am setting the car up more for autox/road course stuff, but want to take it to the drag strip. It will have a torque arm, and full suspension set up. Weight around 3300 w/driver (i'm guessing). Does anyone have any feelings on whether my rear end will hold up. This is w/street tires, and an m6. Thank you all for your help!
NHRAFORMULA00
03-25-2012, 09:44 AM
Do not DUMP the clutch off the starting line, as it will break instantly.It will hold up for a while in a A4,but will not in an M6.You have to slip it off the line.
TurboStangJON
03-25-2012, 12:17 PM
If you are easy it will hold up. However, trying to be easy at the dragstrip is a chore sometimes.
hot93rod
03-26-2012, 04:45 PM
Ok, I appreciate the help. I thought it may do a little better than that, just based on what i read a while back about a guy running 9's on a 10 bolt. His car was only 2800 lbs... and probably a spool as opposed to street gears... So i assume that could make quite a difference. Thanks again!
SuperSlow02
03-26-2012, 06:58 PM
That's called it's either an auto or he dosnt give a crap if it goes because he has a 9" waiting to go in.
TurboStangJON
03-26-2012, 10:20 PM
A close friend of mine had a 4th gen 10 bolt in his 3rd gen and ran 9.40@140 multiple times. However, don't think for a second that if one person has gotten away with it that you will. Especially with a manual....
Tommyv8
03-26-2012, 11:02 PM
If you have rain tires that can't grip worth crap then you probably won't break the differential.
BlackScreaminMachine
03-27-2012, 07:10 AM
^ Wheel hop will though.
If you want a good slip you need to get up on that tire and let the clutch dump off the line @5-6k rpm and hold on. Then shift clean. To do that you do need a good driveline, suspension, and a bias-ply slick.
Been there, done that, broke shit, still learning but I will tell you it is not cheap.
Caught some good air on this run, the right had bout 1 ft off the ground at full extention. Spent the past few years gathering parts to keep it level, straight, and safe and looking for a fall run to get a better slip.
http://ls1tech.com/forums/picture.php?albumid=551&pictureid=2753
Camarokid08731
03-28-2012, 05:05 PM
my car with an a3, 3800 stall, stock rear gears,mac rear cover,and upgraded u joints 60 ftd 1.59 on spray out of the hole a ton of times and is totally fine....but thats an auto m6 is a little rougher but that gives u an idea i guess....im gonna be building mine with a spool and moser axels and c clip eliminators if mine lets go...good luck with yours
