Fueling & Injection - EV6 and EV14
View Full Version : EV6 and EV14
95_transam_lt1
03-25-2012, 08:21 PM
Are the connectors for both of these the same? basically can i use http://www.americanmuscle.com/mustang-ev1-ev6-adapter-kit.html?utm_content=plamustang-ev1-ev6-adapter-kit&utm_campaign=GSNoFitmentV1&utm_source=google&utm_medium=cpc&AMID=mustang-ev1-ev6-adapter-kit-NoFitment&adtype=pla&kw= this on a ev14 injector in a ls1 fbody
1lejohn
03-26-2012, 11:29 AM
Look at this link. http://www.fuelairspark.com/WhatsNew/Files/fastgmgenivfuelinjectoradapterharnesstechsheet.pdf
It depends on what intake manifold some require a different type nose on the injector. I had to use the projected type on my L92 intake. The stock Ls1 does not
1lejohn
03-26-2012, 11:36 AM
Which injector are you going to use?? They alll should fit an LS1 intake. You should need the male EV6 (minitimer) to a female (uscar) adaptor. If using an early LS harness.
95_transam_lt1
03-26-2012, 04:42 PM
If I read that link from ast correctly I can use those adapters
95_transam_lt1
04-08-2012, 02:20 AM
i was going to use ls7 lifters
