5.3l and gtk1000- when will I max the turbo
Old 03-26-2012, 02:45 AM
baggins's Avatar
Default 5.3l and gtk1000- when will I max the turbo
OK so i have a 5.3 with stock heads and wanna know what its gonna take to max out my turbonetics gtk 1000. i know my cam is a bit big (232/234 on a 114) but im not gonna change it. running an 4l80e, stall will be between 3200-3600. How far can i go with this turbo, boost and hp wise?
specs
76mm t4
.96 ar
68mm turbine wheel
4" dp
Thanks in advance- Nick
Old 03-26-2012, 11:24 AM
SPRAYED 01's Avatar
Id say around 700whp it would be out of steam. That will take arOund 17psi.
Old 03-29-2012, 08:58 PM
badss_02's Avatar
I don't mean to hijack your thread but i've been thinking about running the same turbo on my iron 5.7. I'll be right at 10.5:1 and on E85. Any clue what i could get out of that turbo?
Old 03-29-2012, 09:25 PM
baggins's Avatar
forced inductions says only like 700... im hoping for a little more though. ill be on e85 as well
Old 03-29-2012, 11:18 PM
TurboS10's Avatar
68mm turbine is the cork.....
Old 03-30-2012, 04:10 AM
baggins's Avatar
What do you think I could run boost wise before efficiency goes out the window
Quick Reply: 5.3l and gtk1000- when will I max the turbo
