Cadillac CTS-V - Threw some codes
View Full Version : Threw some codes
pho_phizzat
03-26-2012, 02:27 PM
My 05 with 48k miles threw a p0171 and a p0174 left and right bank lean codes. I reset them and have put about 20 miles on since and they have not came back. Could it be a fuel issue? I run 91 octane. Only mods are cai and exhaust that I know of. I made an appointment to have the fuel filter changed tomorrow. Anyone else have this happen?
itsslow98
03-26-2012, 03:21 PM
Prolly 02 sensors. Can't tell you his many times mine shit out when I owned it.
CTSV_510
03-26-2012, 03:26 PM
I would say its less likely that two o2 sensors go bad at the same time than you have some sort of leak in your intake, or dirty MAF sensor.
pho_phizzat
03-26-2012, 04:31 PM
So it is not fuel system related?
07CTS-V
03-26-2012, 05:28 PM
Many people who install CAI's throw lean codes. I did also when I installed a CAI and heads n cam and exhaust. I ended up just turning off the codes.
odthetruth
03-26-2012, 06:43 PM
Its probably CAI related. Make sure there's no leaks in the tubing, and worse case, it may need a tuning. I had this issue when I put on an intake. P0171 and P0174. I went back to stock intake until I can go for a tuning.
CTSV_510
03-26-2012, 06:50 PM
It could be, but more likely an intake leak or dirty MAF sensor. But, changing your fuel filter is a good thing regardless.
pho_phizzat
03-27-2012, 09:10 AM
Ok thank you. Is the fuel filter easy to get to or better to pay someone to do it?
mhhamrhead
03-27-2012, 05:06 PM
I get the same two codes - Randomly at best! I'll go for weeks without issue, then it will happen 3 times in a day.
Thing is, it only happens when the car is really warmed up, and at idle. Never when I'm moving.
My only mod is a Volant, and I figure it has something to do with the CELs.
The car runs and drives perfect.
sod
03-28-2012, 10:12 AM
Fuel filter is really easy to do & to get to. I wouldn't pay someone to do it.
It's on the passenger side frame rail, you'll need a set of fuel line tools (those little round plastic ones) but those are cheap.
actually, you only need 1 size fuel line tool, but they come in a set.
pho_phizzat
03-28-2012, 01:08 PM
Thanks again. I have the tools but took it in to get it done and have the fuel system looked at. Seems to be running good. I have a couple hundred mile road trip this weekend so I will see.
LAYGO
03-28-2012, 01:42 PM
Love google:
http://www.youtube.com/watch?v=DKgQJ-RinXc
