Automatic Transmission - flare nut on the hard line
View Full Version : flare nut on the hard line
zooguy
03-26-2012, 02:35 PM
does any one know what size the flare nuts are on a 1995 4L60e hard line?
last time my tranny guy did some work he used a set of pliers or some thing to tighten down the flare nuts and thus stripping tthem so bad a wrench wont work any more.
zooguy
03-27-2012, 01:47 PM
no one has any idea?
zooguy
03-28-2012, 07:25 AM
nearly 100 people have looked at this and no one knows the answer?
mrvedit
03-28-2012, 09:06 AM
Not to be mean, but I suspect that 100 people don't understand your question. "the nut that holds the tranny line"???
I will assume you mean the cooling lines.
Assuming true, the following thread should help you fix your problem; start at post #19:
http://ls1tech.com/forums/automatic-transmission/217631-braided-line-trans-cooler-lines-4l60e.html
zooguy
04-08-2012, 06:55 PM
bump
i need to know the size of the actual flare nut on the hard line
GMRACER13
04-08-2012, 08:35 PM
They are 1/2".
